1998 Other Jeep Models will not start
1998 JEEP
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
RAYNMARTI
the car was running then just stopped running
and would not start again the motor turns over
Oct 7, 2008 at 5:35 PM
BLACKOP555
  • 10,386 POSTS
what do you mean would not start again till the motor tursn over?
Oct 7, 2008 at 7:07 PM
MECHCURT
  • 184 POSTS
First thing to check for are fire and fuel. Turn the switch on and try and hear your fuel pump in the tank run. Then check at the fuel rail the schrader valve and see if you have fuel pressure there. Be careful it will be under pressure. To check for fire, while cranking use a spark tester on one of the plug wires to see if you have fire. Get back to us after you have tried these tests. Thanks Curt
Dec 2, 2008 at 11:30 PM
BLACKOP555
  • 10,386 POSTS
thanks for that curt. always check for pressure with a pressure guage, safer and it will tell you if you have enough pressure, 10psi matters.
Dec 3, 2008 at 6:22 PM
