My 1998 Jeep Grand Cherokee Laredo wouldn't start one morning. Had been running fine. I found that I had no spark at the coil and replaced the crankshaft sensor and then the coil. I still have no spark! The other strange thing I noticed is that if I turn the ignition key backwards the fuel pump runs constantly. I'm probably going to have it towed to the dealer but wanted to see if there is anything else I should try. I believe I have a PCM problem. Can the PCM be diagnosed at the dealership if I take it out and deliver it to them or do I need to tow the vehicle to the garage? Is there anything else I can try? This is probably going to be an expensive repair.
Feb 9, 2008 at 6:38 AM
