1996 Other Jeep Models transmission over heat and frying
1996 JEEP
126,750 MILES • 6 CYL • 4WD • AUTOMATIC
JEM365
We recently added a lift kit to our jeep. after adding the lift kit we noticed tranny fluid leaking, then the tranny fried. we replaced the trany with a new one that ran fine for about two days. after which the overdrive light stayed on and the tranny over heated then refused to work lost all gears. still leakng fluid. when we checked the stick there where bubbles and it was extremly hot.
Oct 11, 2009 at 11:08 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be replacing the trans oil cooler as it may be part blocked with muck from the original transmission failure, this is a common over sight on may transmissions and this can cause expensive damage to your new transmission, also on some jeep transmissions the clips that hod the cooler lines into the trans are plastic and they can fail easily, causing leaks.
mark (mhpautos)
Oct 12, 2009 at 12:12 AM
JEM365
thanks much will try this coming week. hopefully done by the first snow. will let you know if it works.
Oct 12, 2009 at 5:05 PM
