1995 Other Jeep Models 95 grand cherokee rough idle with cod
1995 JEEP
LEFTYS4JS
  • 4 POSTS
Engine Performance problem
1995 Other Jeep Models V8 Four Wheel Drive Automatic
Hello i recently posted about a miss and hard starting problem, its a 5.2L v8after monitering alittle more its not a miss. more of a rough idle and acts if it wants to die at lights/stop signs also notice at times it wants to die the voltage drops below normal but when accelerating goes back up and stays....new cap and rotor and plugs and wires and still the same..i was able to get 2 codes that i didnt have before they are
32-EGR solenoid circuit -open or short detected in EGR solenoid circuit /EGR system failure required change in fuel/air ratio not detected during diagnostics test..
52-air/fuel at limit-oxygen sensor signal indicates lean air/fuel ratio during engine operation.
where is the EGR solenoid located i could not find it.
If anyone could tell me what i should check or steps i need to take it would be greatly appreciated
thanks
Jan 24, 2010 at 12:31 PM
LEFTYS4JS
  • 4 POSTS
was looking for vacuum leaks noticed the hose from the pcv to the intake was cracked replaced that and now its hard to start and when it does it wont stay running unless i pull the pcv from the intake again it will start ok and run ok not good but better then before
Jan 24, 2010 at 3:50 PM
