1994 Other Jeep Models Turn signals
1994 JEEP
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGPUNFU
i had my turn signals stop working so i checked the fuses and all were fine. i checked the switch and changed it and that didnt work. i changed the relay and that worked but as soon as the flashers were turned off, there was an audible buzz that stayed on as long as the turn signals and or hazards were turned off
Apr 11, 2009 at 6:09 PM
JAMES W.
  • 2,394 POSTS
Sounds like you need a flasher. It sould be located on the underdash fuse block.
Apr 11, 2009 at 6:44 PM
BIGPUNFU
that would cause the relay to buzz?
Apr 11, 2009 at 6:58 PM
JAMES W.
  • 2,394 POSTS
Relay will "buzz" due to bad coil or contacts. low voltage to the coil is sometimes will cause this, but it's usually a bad coil.
Apr 11, 2009 at 9:49 PM
