1994 Other Jeep Models Electrical works-wont turn over
1994 JEEP
126,000 MILES • 6 CYL • AWD • AUTOMATIC
LARRY_IN_OK
Everything electrical works. When key is turned fully to start you can hear the relay sending gas to the unit but nothing else happens. Starter doesn't turn over.
May 21, 2008 at 9:55 PM
Could be the ignition switch, starter relay, park and neutral switch or the starter itself. Hold key at start position and check for power at the black wire at the starter solenoid-do you have power if not backtrack to the items above and also see below for troubleshooting the starting syste.
https://www.2carpros.com/forum/automotive_pictures/12900_st1_3.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_st2_3.jpg
May 22, 2008 at 4:30 AM
