I have a 90 jeep grand wagoneer with a amc 360, It has a miss at idle and low rpms. I have installed accel cap rotor wires and motorcraft plugs .
set the timing and adjusted the motorcraft 2150 carb . Miss is still there. So I removed the factory ford igniton module and wired in a GM 4 prong hei control module. This solved the miss but now when I apply the brakes the jeep dies, it will start back and run until you touch the brakes . It will not do it in park only in gear. Please help before i burn this classic to the ground!
Apr 8, 2010 at 10:43 AM
