2005 Jeep Liberty White Smoke Coming From Engine
2005 JEEP LIBERTY
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
CURT01
2005 Jeep Liberty, 80K miles. While Air conditioning was running idle, white smoke started coming from the area where the radiar water is added. I checked and the radiator was was low. Added water and the problem seem to be resolved. Air conditioner is not blowing cold and I don't want to use the air conditioner again until I have the problem checked out. What could be the problem and approx what should it cost?
Sep 18, 2010 at 9:53 AM
BILLYMAC
  • 2,204 POSTS
Hi sounds like 2 probs one the a/c needs charges and leaks repaired this could be minor or depending where it is leaking a few hundred dollars.
the white smoke was most likely the radiator leaking this would be the 4-5 hundred range
Sep 28, 2010 at 7:37 PM
