2005 Jeep Liberty power window
2005 JEEP LIBERTY
MRSREPIK
2005 Jeep Liberty
My driver side rear window stopped working for no reason. It went down and then would not go back up. How do I fix it? I took the inside door panel off to see if it is out of track. I can't see anything.
Jun 19, 2009 at 6:24 PM
Is the motor getting power? If so, replace it. If there is no power to it, check the switch.
Sep 14, 2009 at 8:26 AM
JGREENWA
I'm not an auto expert - I've had the same problem - but I have an '02 liberty. You don't mention whether the window slides freely (e.g. you can slide it up and down with your hands).
If you can, I suspect its the regulator. I had two of them (both rear) give up the ghost within 6 months of each other (one before the warranty was up and the other after). If that's the case, you'll have no choice but to replace the regulator. The price for the part alone is about $175. It is time consuming to replace to expect the dealer/garage mechanic to charge accordingly for labor. You could also do as I did - use internet resources and learn how to do the repair yourself - as I said its time consuming but not all that difficult.
Good Luck
Sep 22, 2009 at 2:29 PM
