Carrier Bearing or Pinion Bearing problem?
2005 JEEP LIBERTY
59,000 MILES • 6 CYL • 4WD • AUTOMATIC
JENDESANTIS
I had an independent mechanic drive my car due to a humming noise coming from the rear of car. He said it sounds like either carrier or pinion bearing and to take it to the Jeep dealership. Car is there now. I asked service manager if it were one of the 2 things above, would it be covered under 70,000 Power Train warranty and he said no. I pulled warranty paperwork and it says: transfer case and all internal parts, transfer case control module and shift mode motor assembly, axle housing and all internal parts, axle shafts, axle shaft bearings; drive shaft assemblies (front & rear), drive shaft center bearings, universal joints & yokes, disconnect housing assembly, seals and gaskets for listed components only....I am not a car person...do any of the above parts fall under a Carrier or Pinion bearing? I don't trust dealership service and want to be sure I am not being ripped off!!! Thanks!!
Sep 16, 2010 at 7:50 AM
BMRFIXIT
  • 19,053 POSTS
You can wait for them to get back at you with the problem and then you can call the warranty people and ask them
as bearings it should be covered under the warranty
Sep 16, 2010 at 6:48 PM
JENDESANTIS
I received a call from the dealer. Turns out it is the bearings and they are replacing all bearings and it is covered under the Power Train warranty!! Just have to pay the $100 deductible :-)
Sep 17, 2010 at 12:16 PM
BMRFIXIT
  • 19,053 POSTS
Very good
This is more like it
Sep 17, 2010 at 5:21 PM
