I re-installed a power window motor in the passenger front side and I can hear the motor when I push the down button, but when I push up nothing happens. It sounds like it may be a wiring issue, but where? I checked the fuses, circut breakers, I dis-mounted the center console where the switches to lower/raise windows, still nothing. Please help? Also, I have taken it apart and put it together about 6 times, yes I re-installed it back and double checked it. The part in the box I got said that if it didn't work properly to just switchthe up and down wiring, where is that? The connector to the motor? If so, how do I even pull those wires out and switch them? Thank you for your time.
Jul 7, 2009 at 10:07 PM
