When we put the A/C on the engine temperature starts to overheat?
2002 JEEP LIBERTY
42,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKE PANKIEVICH
When we put the A/C on the engine temperature starts to over heat. When we turn the A/C off the engine temperature returns to normal
Jun 8, 2009 at 11:50 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Start with checking that the A/C condenser cooling fan is turning on, and have the radiator, cleaned & flow tested, not just a back flush with a hose as this will not really clean out and deposits that may be blocking many of the cores in the radiator, start here.
mark (mhpautos)
Jun 9, 2009 at 12:17 AM
SANCHEZ22
I have the same problem it only overheats when the a/c is on but I have changed the thermostat, radiator, there are no leaks and the fans are turning on. The water pump is fine too, at this point I am not sure what else it could be?
Sep 14, 2022 at 8:13 PM
SANCHEZ22
Does this happen at any speed, or does it seem limited to in-town driving (stop and go)? Also, when the A/C is on, do you ever notice a squeaking from the A/C belt or anything that seems out of the ordinary?
Let me know. Also, it sounds as though you have done a lot of work already. Was the radiator cap replaced? Also, is there any noticeable usage of engine coolant?
Take a look at this link. It describes the symptoms of a faulty head gasket and what to look for. There are a few things that simply require inspection. Check them and let me know if anything mirrors what you find.
Sep 14, 2022 at 8:45 PM
SANCHEZ22
It only happens while driving in town, mostly when the car is stopped. The radiator doesn’t have a cap, only the coolant reservoir, it works fine. The coolant levels have not changed, it’s still on the “filled level”. When I had the radiator changed, it was not burped could that be a reason for it to overheat? Other than that, when i don’t use the A/C the car does not overheat.
Sep 14, 2022 at 9:25 PM
Okay, the idea that it happens when driving in town indicates it requires more airflow than the fan can provide.
So, two things. First, the coolant reservoir cap is vented. But it needs to hold a specific amount of pressure. If it isn't holding enough, the coolant's boiling level drops and can overheat easier.
Next, if the cooling system wasn't properly bled, absolutely that can cause what is happening. Don't laugh, but when it starts getting hot, does the heater work?
Sep 15, 2022 at 6:25 PM
