2002 Jeep Liberty oil little discolored
2002 JEEP LIBERTY
107,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOEYSDADDY06
checked the oil and the cap had a little discolor on it little cream color just a little not much
Jan 26, 2009 at 8:14 PM
Hi:
This is caused by moisture. Make sure the coolant level isn't dropping so we can eliminate the chance that it's a headgasket. If that is ok, chances are you need to replace the PCV valve. It's on the valve cover. When replacing it, make sure the hose attached to it isn't clogged.
Let me know what you find.
Feb 27, 2009 at 10:52 AM
