96 Grand Cherokee Laredo Rough Idle
1996 JEEP GRAND CHEROKEE LAREDO
LUMBERJACKNICK
I have a 1996 Grand Cherokee Laredo I6 4.0L that when you start it it sounds fine then after about 3 minutes the engine sounds like its going to die and the RPM's drop to almost stalling. it only lasts a minute or so. now it seems to have a rough idle. I have replaced the fuel filter and plugs but this started before this. it has 135k on it. Everything else has been kept up but i think after a few rough towing trips a few months back it might have screwed something up. Please help....
Oct 28, 2007 at 11:30 AM
2CARPRO JACK
  • 11,533 POSTS
For starters clean out the throttle bore (where the air intake tube goes to engine) with some carb spray and a rag. On the throtle body is the IAC motor (lowest sensor on throttlebody) held on with 2 Torx screws. Remove it and clean it well with carb spray, careful not to loose the small o'ring
Oct 29, 2007 at 7:48 AM
