2007 Jeep Laredo loss of power on incline
2007 JEEP GRAND CHEROKEE LAREDO
49,000 MILES • 6 CYL • 4WD • AUTOMATIC
RVMETALMAN
I have a 2007 jeep grand Cherokee with a v-6 engine. the problem I have is when I start driving up a incline about 30 miles per hour or so the engine will drop power almost like the fuel shuts off. as you push down the gas is just bogs. when you back off a little it will all of a sudden take off. I also want to mention it does not do it all the time.
May 28, 2010 at 9:36 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 28, 2010 at 10:06 PM
