Yes, a TPS could be your answer. I am unfamiliar with the newer engines but I know that TPS has caused vehicles to surge because of the torque converter engaging and disengaging. Also, sometimes a sensor will not set your check engine light off because the sensors need to break a certain barrier before that happens but they could still be bad. If you have a check engine light on, some of your local auto parts stores will check your codes for free just call to confirm that they have this capability first.
Dec 25, 2009 at 8:36 AM
