2003 Jeep Laredo turn sigenals
2003 JEEP GRAND CHEROKEE LAREDO
SNOPPY DOG
Electrical problem
2003 Jeep Laredo 6 cyl Four Wheel Drive Automatic
the turn sigenals would work some of the time now thay dont work at all .i checked the fusses and changed the turn sigenal switch (thay call it a dimer ) dont no what to try next please help
i dont no how to donate
Mar 9, 2010 at 6:34 PM
BEEF99
  • 152 POSTS
Are your fuses shorting out at all? Sometimes there can be a short in the system even if the fuses do not blow. Whatever you do, do NOT put a higher rated fuse in place of the original one as this may cause a vehicle fire. IF your vehicle is equipped with a towing package and has a pigtail for a trailer plug in, this could be your cause as they do short out often on Jeeps. I would suggest buying a Chilton's book for your vehicle at an auto parts store, they run about $15 and look at the wiring diagrams and follow the suggestions in the book to locate your issue. You have to trace where the problem is and the book will explain in further detail on how to do this.
Mar 9, 2010 at 7:14 PM
