The Malfunction Indicator Light came on and oil was leaking from the valve cover which the gasket was replaced. The oil damaged the starter which was also replaced.
A couple of months later my temperature gauge is 3/4 to reach the H and caused the radiator hose to bust. After the diagnostic was performed reported a Thorttlle Position Sensor Circuit Malfunction and the Fan Control Relay with Thermostat was replaced along with the radiator hose.
Today the Temperature Gauge is 3/4 again; oil is leaking from the valve cover again!
There has to be something causing this and THEY (automotive shop) don't seem to care. I cannot continue to replace these items over and over.
Your valuable comments are welcomed.
Aug 26, 2010 at 10:14 PM
