Engine Cooling problem
2002 Jeep Laredo 6 cyl All Wheel Drive Automatic
how to troubleshoot the electric cooling fan?
I assume it should come on at a certain water temperature, but it doesn't.. turning on the AC doesn't make it run either, i'm not sure if it's supposed to run when the AC is running, but i think it should. Just installed new thermostat(engine) as the gasket was leaking. at idle, or 'not moving' it heats up to red zone, but driving it around the block cools it back down. Thanks for any tips
Mar 30, 2009 at 3:15 PM
