2001 Jeep Laredo FUEL INJECTOR CHECK
2001 JEEP GRAND CHEROKEE LAREDO
109,000 MILES • V8 • 2WD • AUTOMATIC
LAURAL21
I hooked up and got 3 different trouble shooting codes 3 feul injectors po204 205 206 car is missing bad. what could it be
Oct 17, 2009 at 8:16 AM
This is going to sound strange but you need to have the throttle position sensor (TPS) checked with a scan tool or lab scope.
It has been shown that a TPS with 0.02v or more may cause injector fault codes. If there is a speed control switch input to the Powertrain Control Module (PCM) that is shorted to voltage, it may cause the same problem.
Nov 9, 2009 at 10:13 AM
This is going to sound strange but you need to have the throttle position sensor (TPS) checked with a scan tool or lab scope. It has been shown that a TPS with 0.02v or more may cause injector fault codes. If there is a speed control switch input to the Powertrain Control Module (PCM) that is shorted to voltage, it may cause the same problem.
