2001 Jeep Laredo
2001 JEEP GRAND CHEROKEE LAREDO
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
OMARIN4
  • 7 POSTS
Where is located the IAC Valve, I think I have a problem with this, when I start on mornings or with the jeep cold by the first time I need to keep the acelerator on 1000 rpms by 1 minut around because if I remove my foot the truck turns off after the minut the truck runs perfectly
Dec 29, 2009 at 2:40 PM
https://www.2carpros.com/forum/automotive_pictures/12900_IACMjeeplaredo_1.jpg
Dec 29, 2009 at 5:24 PM
OMARIN4
  • 7 POSTS
thanks then the idle air control motor is the valve iac???
Dec 29, 2009 at 7:59 PM
Same purpose, different names-could be ISC
Dec 29, 2009 at 8:27 PM
OMARIN4
  • 7 POSTS
ok but I'm looking the IAC Valve can you tell me where is it?
Dec 29, 2009 at 8:29 PM
The IACV is the same as the Idle air control motor its on the pic I've given you earlier
Dec 29, 2009 at 8:32 PM
OMARIN4
  • 7 POSTS
ok tank you the I'm going to change as son as posible because when I start the engine on mornings I need to keep my foot 1 minute on the acelerator because if I leave to acelerate the jeep is turn off the rpm's comes low
Dec 29, 2009 at 8:49 PM
