1998 Jeep Laredo radiator spewing antifreeze
1998 JEEP GRAND CHEROKEE LAREDO
174,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGDADDYSTERN
my ac started working but when i cut the jeep off antifreeze spewed out. Stopped using the ac nothing came out. Then it spewed antifreeze again and overheated without the ac on. Filled it back up and drove it but nothing came out. What could be causing this problem? Doesnt leak antifreeze all the time. My temp gauge normally sits at 210, but was at 220 when it ranhot. Is 210 the norm for this type ofvehicle as well?
Jun 27, 2010 at 2:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
could be that cooling fan(s) are not coming on properly. also remove and test thermostat. if OK may need to test cylinder compression for possible cracked head or head gasket. 210F is good operating temp.
Jun 27, 2010 at 3:27 PM
