1998 Jeep Laredo Heater blower intermittent
1998 JEEP GRAND CHEROKEE LAREDO
EAMONHEGERTY
  • 9 POSTS
Heater problem
1998 Jeep Laredo Engine Size unknown Four Wheel Drive Automatic 110000 miles
The car is a Grand Cherokee Laredo. The heater blower is intermittent. Sometimes it works, sometimes it doesn't. I bypassed the controls and connected 12V directly to the blower and it worked fine. I've removed the heater/blower control unit from the dashboard but don't see anything obviously wrong with it. There is a clear plastic pipe coming out of the back of the control unit (which I don't understand) as well as normal electrical wiring. What is the likely cause of the intermittent operation?
I made a donation via Paypal for this question.
Feb 21, 2008 at 10:40 PM
2CARPRO JACK
  • 11,533 POSTS
Most likely the fan speed resistor is shorting out.Should be in the HVAC plenum near the blower motor, just follow the wires from blower back to it
Feb 22, 2008 at 7:29 AM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_Switches_1.jpg
Check these two out and you can figure out the cause! Thanks for the donation!
Feb 22, 2008 at 7:33 AM
