1997 Jeep Laredo no spark, no gauges
1997 JEEP GRAND CHEROKEE LAREDO
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
POCKETRODS
  • 11 POSTS
while driving jeep died. will turn over no spark. have replaced crankshaft sensor, camshaft sensor. gauges do not move, low gas light stays on when key on but have over half a tank. engine light doesn't come on. have checked all fuses and asd relay. wiring all appear in good shape. can hear fuel pump when key is on. any ideas?
Jul 4, 2009 at 12:47 PM
JDL
  • 16,098 POSTS
hello, if there is no primary voltage to coil, or the injectors with the engine cranking, check for voltage input to the asd relay, if you haven't already. Voltage for the switch side of relay is battery voltage, hot all the time. The voltage for the coil side of relay is ignition feed, goes hot with the key on. You can unplug relay and use a testlite.
Jul 4, 2009 at 1:34 PM
