1997 Jeep Laredo Bad Camshaft sensor
1997 JEEP GRAND CHEROKEE LAREDO
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
POCKETRODS
  • 11 POSTS
will a bad camshaft sensor affect the gages ? jeep turns over but won't start has no spark. gages don't move when key is turned on. have replaced crank shaft sensor, didn't help. Thinking maybe camshaft sensor does this make sense?
Jul 3, 2009 at 10:05 AM
JDL
  • 16,098 POSTS
Hello, several issues can cause no spark, but, I don't know why that would effect the gages, unless there is a problem with the ignition switch.
Have a helper crank the engine, check for primary voltage at the coil and injectors. If there is none, check the voltage circuits going to the asd relay. You can unplug the relay, turn the key on, you don't have to crank it, use a testlite on the terminals where the relay plugs in, two of them should be hot.
Jul 3, 2009 at 10:56 AM
POCKETRODS
  • 11 POSTS
no voltage asd two are hot. Ingition switch?
Jul 4, 2009 at 3:28 PM
JDL
  • 16,098 POSTS
If your saying, two of the terminals at the asd relay are hot, with engine cranking, no, I don't think it is the switch. Maybe I didn't understand your last post?
Jul 5, 2009 at 8:35 AM
