well i put a new radio in my grand cherokee and initially i had an extra mute wire on my new wiring harness and an extra wire from the factory with a female connector that slid on a metal tab sticking out from the back casing of the factory radio so naively put them together but after seeing how my voltmeter reacted when i would turn venting on i came to the conclusion it was a ground that appeared to be for controls around the radio, but since that with my vehicle off and having the radio on for 5 mins or so the voltmeter would go down the the warning underline and just drop all the way down and activate a check gauges alarm, so i changed that but now it is going from 14 volts when running to acting like its drained within 2 minutes of being shut off it will normally still crank and ive been told to check my alternator but would like some different input because ive charged my battery on a charger and it pretty much just does the same thing but a lil more length, tho i do find the notion of a regulator in the alternator being bad plausible but would like a better idea before i take it out, another thing i did that was dumb was turned the battery charger up to 30 amps which i didnt realize could potentially damage things but i do remember some odd noises when i turned the key with that on
May 8, 2009 at 12:06 AM
