Transmission problem
1996 Jeep Laredo 6 cyl Four Wheel Drive Automatic
When I leave for work (20 miles away) in the morning my jeep shifts fine for the first 10 miles (stop lights 6 miles then expressway) then I get into some stop and go traffic and my jeep down shifts from overdrive to 3rd gear then up shifts then down shifts, stays in 3rd until I put it in neutral let the r's comback down and put it back in drive. At this point I am getting off of the e-way back into city driving, the jeep does it a couple of times then settles down execpt that it start out in second even if I put it into 1st with the gear selecter. After work 9 hours later, it starts out in second and if I leave the gear selecter alone, after 5 miles the trans drives like nothing is wrong as long as I baby it off the stop lights and lmoderately excellerate. It does this every day, but if I drive it around like shopping trips, as long as I don't hit the e-way it is fine. The engine temp is normal and no idiot lights are on. I just got the Jeep and took it in for the normal prevenative maint. they said the trans fluid was a little over filled and looked burnt, but did not reccommend changing it because I did not know when it was changed last and putting new fluid in could cause more damae. 1) Is this true about the fluid change or should I try changing the filter and fluid? 2) Is this a shift control module issue or is it time to rebuild?
Apr 8, 2010 at 11:17 PM
