1995 Jeep Laredo Replacing drive shaft
1995 JEEP GRAND CHEROKEE LAREDO
145,000 MILES • 6 CYL • AWD • AUTOMATIC
LITTLEDEVILZERO
I am planning on replacing the front drive shaft in my grand cherokee I was wondering what parts I needed to complete this myself, also I cant tell if the CV joint is part of the drive shaft or not. The mechanic i took it too said somthing about a knuckle the was wearing out could you tell me what you guess he is talking although I still plan on replacing the whole thing.
Sep 22, 2009 at 5:42 PM
If you are refering to the drive shaft, chances are he is refering to a universal joint. Unless the drive shaft has been damaged (BENT) it will be fine. A u-joint will be under 20.00.
As far as a CV joint, that deals with the front axle not the driveshaft.
Sep 25, 2009 at 12:13 PM
