1995 Jeep Laredo
1995 JEEP GRAND CHEROKEE LAREDO
RICHARD URIAS
Engine Mechanical problem
1995 Jeep Laredo 6 cyl Two Wheel Drive 178000 miles
Hello once again! How do i pull out an oil pump and install one, what steps do i take? on a 95 4.0 jeep cherokee laredo 2 wheel drive.
Mar 17, 2010 at 3:39 PM
1.Remove oil pan as outlined under Oil Pan/Service and Repair.
2.Remove oil pump to cylinder block retaining bolts, then the oil pump and gasket. WARNING: Do not disturb positioning of oil pump strainer and tube. If tube is moved, a replacement tube and screen assembly must be installed to prevent pump cavitation.
3.Reverse procedure to install, noting the following:
a.Use a new oil pump gasket.
b.Tighten retaining bolts to specifications.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Mar 17, 2010 at 4:13 PM
