1994 Jeep Laredo gas pump
1994 JEEP GRAND CHEROKEE LAREDO
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
RED JEEP
What is the pressure for the gas pump on a 1994 Jeep Laredo? My car has difficulty starting in cold and wet weather and mornings. Once the vehicle is warmed no problem.
Mar 16, 2010 at 7:21 AM
BEEF99
  • 152 POSTS
Your fuel pressure should read 39psi give or take one psi. This is testing at the fuel relief valve located on your fuel rail. It has a blcak cap similar to a bicycle's air stem. If taking a vacuum line off, the reading should go up 8-10 psi. If the pressure does not go up after removing a vacuum line, check the pressure regulator vacuum line or the pressure regulator for faults. Your pressure regulator is on the forward side of your fuel rail on the end with a vacuum line hooked to it.
Mar 16, 2010 at 10:40 AM
