HUB & BEARING
Removal
Raise and support vehicle. Remove wheel, caliper and rotor. Remove cotter pin, nut retainer, hub nut and washer. Remove hub-to-knuckle bolts. Remove hub from steering knuckle.
Installation
Apply wheel bearing grease to hub bore in steering knuckle and install hub and bearings. To complete installation, reverse removal procedure.
NOTE: Hub bearings cannot be serviced. If defective, replace complete hub assembly.
Feb 13, 2009 at 5:46 PM
