ok so my power steering gear box was leaking...so i figured i would do a rebuild myself! pita! first time i moved the piston to far out and lost the ball, and put the old o-ring for the end cap in by accident. so it leaked bad, pull the gearbox, and tested it with soap and water to be sure. it was the end cap.... pulled retainer ring, and end cap blew off with the piston throwing the balls everywhere! opps forgot to turn the air off! so i cant find 1 of the balls! there should be 24 and i have 23 im ready to put it back together. so my question is!
should i be concerned about that 1/4in ball? a quater in ball missing wiould increase space between each ball by about 1.1mm if i did my math right!
Dec 17, 2009 at 4:53 AM
