1999 Jeep Grand Cherokee rod bearings
1999 JEEP GRAND CHEROKEE
95,000 MILES • V8 • 4WD • AUTOMATIC
ROBD4860
changed rod bearings torched at 45 used old bolts engine turned over 1 tim then locked up
Sep 27, 2010 at 8:00 PM
Did you mike the crankshaft rod journals for taper wear and use the plastigauge before you select the undersized bearing. If not its the wrong size bearings or the crankshaft itself
The best thing to do is get a crankshaft kit -
Sep 28, 2010 at 7:11 AM
