changed rod bearings torched at 45 used old bolts engine turned over 1 tim then locked up
Sep 27, 2010 at 8:00 PM
CERTIFIED EXPERT
Did you mike the crankshaft rod journals for taper wear and use the plastigauge before you select the undersized bearing. If not its the wrong size bearings or the crankshaft itself
