Engine stalls at idle
2015 JEEP PATRIOT
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
STPHKEN
It will run for about 10 minutes then shut off. On the road vehicle stays running with A/C on. Also vehicle shuts off when disconnecting battery while running.
Aug 29, 2020 at 7:21 AM
When you disconnect the battery, you are opening a circuit, so that isn't surprising that it stalls. As far as the idle issue with the A/C, that could be a couple things. The electric throttle body will adjust the throttle blade for idle control. If that is not working, the throttle body itself needs replaced. It isn't serviceable. However, lets start with something other that can cause an idle issue.
Once of the most common causes of a stall at idle is an engine vacuum leak. Take a look through this link and see if it is something you are comfortable doing:
That is where I would suggest starting. If the check engine light is staying on when the engine is running, we need to have the computer scanned for trouble codes. That can help point us in the right direction.
Here is a quick video showing how it's done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scan tool, but most parts stores will do it free of charge. If the light is staying on, have it done and let me know what codes are retrieved.
Let me know,
Aug 29, 2020 at 1:51 PM
STPHKEN
No engine light is on, what are the chances that the MAF sensor could be dirty or no good? I'm currently trying to locate it. I will do some research on the throttle body. Thank you for responding.
Aug 31, 2020 at 12:27 PM
Can you confirm if this is a 2.4L or a 2.0L?
Take a look through these links and let me know if they help.
https://www.2carpros.com/articles/mass-air-flow-service
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Sep 1, 2020 at 6:23 PM
