Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Jeep
Liberty
Engine
Symptoms
Not Running
Cranks but will not start
2002 JEEP LIBERTY
200,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
DALTON59
MEMBER
FOLLOW
Car was missing and then it would not start at all. Have replaced plugs crank sensor, cam sensor and coils. Still fires but will not start.
Dec 5, 2018 at 10:05 AM
CERTIFIED EXPERT
Good afternoon,
Are there any codes stored in the PCM?
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
Have you tested for fuel pressure? You can try to spray some starting fluid into the air filter and see if it starts and stalls. That will tell us if it is fuel related.
Did you check for spark?
Lastly, did you test for compression?
You need fuel, spark and compression for this to run.
Dec 5, 2018 at 12:14 PM
DALTON59
MEMBER
No codes. Have checked all that you asked. It has me stumped Tried starting fluid too it did nothing. Did not even try to start it just kept cranking.
Dec 6, 2018 at 10:15 AM
DALTON59
MEMBER
Everything works fine but it just will not start.
Dec 6, 2018 at 10:16 AM
CERTIFIED EXPERT
Did you verify spark at the spark plugs?
What was the compression?
Dec 6, 2018 at 10:29 AM
DALTON59
MEMBER
My friend is a mechanic and he did both and said the compression was good.
Dec 6, 2018 at 10:35 AM
DALTON59
MEMBER
He is thinking it may have jumped time, but no indication it has.
Dec 6, 2018 at 10:36 AM
CERTIFIED EXPERT
He is a mechanic? If the compression is good, then it is not the timing. If the timing was an issue compression would be off.
He missed something here. I would look for someone else to help you with your checks.
Dec 6, 2018 at 10:49 AM
DALTON59
MEMBER
Is there anything else that you could think it could be? I am scratching my head here.
Dec 6, 2018 at 10:58 AM
DALTON59
MEMBER
The guy I had check compression is only mechanic I know.
Dec 6, 2018 at 10:59 AM
CERTIFIED EXPERT
You need to start with basics.
1. Spark
2. Fuel pressure. Need exact reading not it is okay.
3. Compression. Need exact numbers.
If you cannot do it yourself, I would consider a mobile tech to at least do this portion of the testing.
Dec 6, 2018 at 11:03 AM
DALTON59
MEMBER
He had exact reading I just did not write it down.
Dec 6, 2018 at 11:17 AM
CERTIFIED EXPERT
Okay, I want to help but remember I am here and not there and I need exact information.
Keep me updated.
Dec 6, 2018 at 11:19 AM
DALTON59
MEMBER
No problem. Thank you. I will do that.
Dec 6, 2018 at 11:41 AM
CERTIFIED EXPERT
You are welcome.
Dec 6, 2018 at 11:54 AM
DALTON59
MEMBER
Just an update here. Timing chain gear broke.
Dec 9, 2018 at 1:00 PM
CERTIFIED EXPERT
Oh, sorry to hear that.
Most likely you have damaged valves from that issue. Then I would like to know what caused it to break. They do not just break for no reason.
I would be ready to consider changing the engine at this point.
Dec 9, 2018 at 1:19 PM
DALTON59
MEMBER
Picture.
Image (Click to enlarge)
Dec 9, 2018 at 2:03 PM
DALTON59
MEMBER
Think it is called the key way.
Dec 9, 2018 at 2:04 PM
CERTIFIED EXPERT
Yes, that is correct.
Dec 9, 2018 at 2:09 PM
