1984 Jeep CJ7 oil in air breather
1984 JEEP CJ7
134,000 MILES • 6 CYL • 4WD • MANUAL
WPITTS1
why would i have oil in my air breather
Oct 15, 2010 at 11:49 PM
CJ MEDEVAC
  • 11,004 POSTS
See my profile,
I can assist you on many of your CJ problems.
I answer the CJ5 & CJ7 forums alot.....Check 'em out!
Several possible causes......some not real good.
PCV system not working or not to its full potential (we can check this out, several factors with this)
Low Compression----Lots of "Blowby" past the rings (we may can improve some, without a rebuild)
Timing off
Running bad (vacuum leaks, Carb adjustments)
Are you auto mechanical? (are you able to perform simple wrench turning on your rig?)
Have a Manual? Which?
I will stay with you thru-out this, Keep me informed in detail----whats been done etc.
What sorta condition is your Jeep and engine in?
Spill your guts, I like fixin' CJs!
Your Turn
The Medic
Oct 16, 2010 at 12:36 AM
