1984 Jeep CJ7 brakes master cylinder clutch solenoid rese
1984 JEEP CJ7
158,000 MILES • 4 CYL • 4WD • MANUAL
HERB ROUSE
I just changed my brake master cylinder and the clutch solenoid resevoir. I have tried to bleed the air from both systems but can't seem to build any pressure on either the brake or clutch pedals.
I haven't used this site before
May 29, 2010 at 9:32 AM
CJ MEDEVAC
  • 11,004 POSTS
see my profile, Explain your bleeding technique (sorta quick steps, do not go into big detail) (I will do that for you) Did you do a bench bleed? (if not I can help you do it on your Jeep, really EZer than off the Jeep. See post "85 CJ 7 Stalls When Hot" (14 responses, below yours in forum) You will see the extent I am willing to aid you with your problem. Do you have a manual, which one? Let me sorta know your auto repair experience (so I do not talk down to you!)....will help regardless, some experience available on your end, makes things go faster! I am a member, just like you, except been here over a year, I AM NOT A PAID MECHANIC. I have 29 years of CJs as a primary driver, my Babies, have not been in a repair shop since 1987 (other than alignments)....I do all the work, inlcuding every Restoration that I drive....I know CJs very well! I have answered most of the CJ 5/7 Questions---investigate me! Please Respond--and If you want a paid mechanic to answer this, I will back out of this! Love, Turddog My 2nd Jeep 1979 CJ 5 258---in 1983
https://www.2carpros.com/forum/automotive_pictures/411289_STUD_83_2.jpg
May 29, 2010 at 10:06 PM
