Allright CJ Guy, We will explain some stuff, I know you are new with Jeep, Be gentle and He will do you right.
Dependent on how far you want to carry this, a Chilton Manual would be your best and least expensive route...I RECOMMEND "Chilton" part # 8034 or its newer edition for CJ-5, CJ-6, CJ-7, Scrambler, Wrangler 1971-1990 Repair Manual (If newer is for CJs only, get it........My manual, bought a good while back, has good diagrams and decent descriptions and it is a LARGER BOOK! (about $30-$40)
"Haynes" Manual is very VAGUE with the steering column. I would skip it for the ignition switch problem, but some manuals offer different Pics and it may help on another problem-----I have about 12 Jeep manuals, and 15 or so for other rigs I have/had
The very best you could do is a AMC service manual for "your year" or a close-by year (my 1979 manual would even get you 98% of the way thru, with very minor changes from year to year)....This would be about a $75-$130 investment, and could be found at FYI MANUALS on the internet.....It is the Absolute Best Manual to Have....It is written for 2nd Graders, has many Real PICS and Diagrams...Many test procedures-----Most of the other manuals "Steal" from this one...This is the so-called Bible.
I can maybe talk you thru doing the actual "KEY SWITCH" or "LOCK CYLINDER"----A reference would still prepare you and Let you know the correct names of the parts "WE" would be dealing with. As long as you did not jump ahead, nothing would get broke----most people get impatient and break out the Hammer and screwdriver! (I Know some tricks)
As for wiring, there will be none associated with the cylinder itself
The turn signal swith would come into play, a little, but if its good---no need to replace it, however if its bad---NOW is the best time!-----It just plugs in near the base of the column----unless someone has "Butchered it" (those wires) It will be relatively EZ
Are you mechanical or have pals that way?
Do you have access to basic tools/pullers?
I CAN AND WILL HELP--Your help is appreciated too, for I type slow....if you comprehend well, I won't have to talk 1st Grader---things will move faster.
If you could at minimum read up on it, I will give you the REAL WORLD way to do it, and you will understand better. Sometimes books assume you understand....But once thru it with experienced help---You will be an expert!
The 2car guys sorta suggested a name change ( no likey the Dog name) So I picked CJ MEDEVAC....Better?
Did you see/read "1985 CJ 7 Stalls When Hot"?
If you will view my Walmart Stuff, you will see how SERIOUS and Time consuming I am with making a Jeep Better. (RE: PM, I sent)
Please Respond,
The Medic
Jun 7, 2010 at 9:16 PM
