The engine was overhauled at 80,000mi with a new starter assembly. At 120,000 the starter/flywheel failed with the starter solenoid chipping several [4-5] teeth from the flywheel. A new set [starter/flywheel] was installed. In less than 900mi the same type of failure. Thrust bearing clearance is within tolerance. Please advise possible cause and solution. THANK YOU: WME
Jan 1, 2010 at 8:27 PM
