1978 Jeep CJ5
1978 JEEP CJ5
TORRESARTHURR
  • 4 POSTS
Engine Mechanical problem
1978 Jeep CJ5 6 cyl Four Wheel Drive Manual 90k miles
I was driving, it started to spit and sputter, oil pressure dropped from 60+ to around 30, will not hold an idle, runs rough and blows black smoke now?
Sep 23, 2009 at 11:29 AM
CJ MEDEVAC
  • 11,004 POSTS
need more info...did spit+sput have any metallic sounds
Sep 23, 2009 at 11:20 PM
TORRESARTHURR
  • 4 POSTS
I did a compression test cylinders ranged from 90psi to 120psi no funny noises top or bottom?
Sep 24, 2009 at 9:09 AM
CJ MEDEVAC
  • 11,004 POSTS
Carb has a FLOAT/FLOAT LEVEL....or.....NEEDLE and SEAT.......BREAKAGE...or...ADJUSTMENT ISSUE
Sep 24, 2009 at 8:44 PM
TORRESARTHURR
  • 4 POSTS
that's what it was, I pulled the carb yesturday and found a pool of fuel in the intake and I just tried your test method and it acted just like you said, ran very eratic then smoothed to a good idle and stalled once the float bowl was emty. THANKS
Sep 25, 2009 at 9:56 AM
CJ MEDEVAC
  • 11,004 POSTS
Glad to hear you have isolated the problem
Sep 25, 2009 at 11:47 PM
TORRESARTHURR
  • 4 POSTS
Yes that was it I thank you dearly, she has been back on the road for 2 days.
Sep 28, 2009 at 2:08 PM
