Rear wiper
JEEP CHEROKEE
DSINKA
This site rocks.. just found it and now it's bookmarked..
Anyway, i have a 1998 Jeep cherokee classic with 190,000 miles on it....My rear wiper blade has a sprayer nozzle on it, but i broke it. I cannot find another one online or anything dont really want to got to the junkyard..there has to be somewhere i can buy one online or something right?. Also, my rear wiper arm that dispenses this washer fluid isnt dispensing it...does the motor that moves the arm also pump the fluid? my arm still works and my front wipers still work and spray fluid so if i buy a new motor will it also start pumping fluid? Last question and i will donate to your cause buddies, my car jeep sometimes when parked on an incline wont start..i found that if i shove the gear shifter up past the park it will start...shifter linkage??? if this sounds right please tell me, also where is it? ..thanks guys. i will be eagerly awaiting yur reply.
Derek
Dec 27, 2006 at 8:27 PM
2CARPRO JACK
  • 11,533 POSTS
Welcome. The rear wiper piece might be available from Jeep, otherwise its off to the junk yard.The washer lines get plugged up from the washer fluid drying, be sure all lines are clear before replacing the pump.If you have power at the pump and its not working then you need another.The starting issue could be the shifter adjustment or the Neutral Safety Switch adjustment. Good Luck
Dec 28, 2006 at 9:25 AM
