OIL SMELLS LIKE GAS
JEEP CHEROKEE
1MIKE2MANY
1988 Jeep Cherokee, 6 cyl. 4.0 200,000 miles.
Overheated on a cold day. I replaced thermostat now it cycles about once every couple of minutes, and the oil smell like gas.
Jan 16, 2007 at 1:10 PM
MWHITNEY
  • 63 POSTS
sounds like a head gasket is broke. try to get a compression test done but pull all the spark plugs out so if air can escape from the other cylinders.
Jan 16, 2007 at 7:52 PM
1MIKE2MANY
[quote:a83cc5ad9c="mwhitney"]sounds like a head gasket is broke. try to get a compression test done but pull all the spark plugs out so if air can escape from the other cylinders.[/quote:a83cc5ad9c]
That is my thought too..however it doesn't show the other symptoms of a blown head gasket
Jan 16, 2007 at 7:56 PM
