Jeep O2 sensor problems
JEEP CHEROKEE
JDEMSEY
I have a 99 Cherokee sport, 4.0I6, 150,000mi. I had to replace the downstream O2 sensor wiring harnesses and sensor because they were ripped out by a stick.(dont ask, its a jeep). I am still getting a code of PO138 that says high voltage to sensor. When I look in the Chiltons manual, its says short to voltage. What could be causing this and where should I start looking? The jeep runs fine other wise. Thanks for the help.
Jason
Oct 11, 2007 at 9:54 AM
CARUNDELL
  • 602 POSTS
[quote:5b45b27174="jdemsey"]I have a 99 Cherokee sport, 4.0I6, 150,000mi. I had to replace the downstream O2 sensor wiring harnesses and sensor because they were ripped out by a stick.(dont ask, its a jeep). I am still getting a code of PO138 that says high voltage to sensor. When I look in the Chiltons manual, its says short to voltage. What could be causing this and where should I start looking? The jeep runs fine other wise. Thanks for the help.
Jason[/quote:5b45b27174]
Hey Jason,
Did you check to see if the fuse for that O2 was blown? It should be in the underhood electrical center. If its ok then I would double check your wiring and maybe inspect further up the harness for possible damage. Let me know!
Chris
Oct 12, 2007 at 5:37 AM
