jeep leaking water
JEEP CHEROKEE
JABECNO
I have a jeep cherokee laredo 1997 v8-- it has a problem with the temperature going above 210 and leaking water when the air conditioner is on (doesn't leak or run hot when the a/c is off). New water pump was put on, and problem still happening. What else could wrong?
Jul 10, 2007 at 12:04 PM
SERVICE WRITER
  • 9,123 POSTS
I believe what you are seeing is the condensation from the a/c system-(normal) All cars "leak" water when the a/c is on.
And that is good news!
Jul 10, 2007 at 3:05 PM
JABECNO
no, it's large amts of water and antifreeze (so much it goes below the fill line daily). Could something else be broken to cause the leakage just when a/c has been running?
Jul 10, 2007 at 3:08 PM
SERVICE WRITER
  • 9,123 POSTS
Thats strange, or mis-interpreted.
If you drive without the a/c on for a week the anti-freeze doesn't drop?
If both fluids are leaking from the same place- the evaporator drain, then I would suspect the heater core. You need to pressure test it and see where the coolant is coming from.
Jul 10, 2007 at 6:52 PM
