shifting back and forth from overdrive to 3rd
JEEP CHEROKEE
MATT_MAN
My new 1989 Cherokee keeps shifting down out of overdrive, revs in 3rd and switches back to OD quite frequently on the highway. When I drive over 110kmph it does it less but still here and there. I assume this is a vacuum problem. Can anyone give me some advice? Thanks
Feb 4, 2006 at 12:14 PM
2CARPRO JACK
  • 11,533 POSTS
The shifting issues you are experiencing with your 1989 Jeep Cherokee could indeed be related to a vacuum problem. In older vehicles like yours, the transmission shifting is often controlled by a vacuum modulator that uses engine vacuum to determine the appropriate gear shift points. Here are a few steps you can take to diagnose and potentially address the issue:
Check vacuum lines: Inspect all the vacuum lines in your engine bay, paying close attention to any that are connected to the transmission or vacuum modulator. Look for signs of damage, leaks, or disconnected lines. Repair or replace any damaged or faulty vacuum lines as necessary.
Test vacuum modulator: Locate the vacuum modulator on the transmission (it should have a vacuum line connected to it). Check the modulator for signs of damage or fluid leaks. Remove the vacuum line and inspect it for any signs of transmission fluid. If fluid is present, it indicates a faulty modulator, and it should be replaced.
Test vacuum pressure: Use a vacuum gauge to measure the vacuum pressure in the engine. Consult the vehicle's manual or a repair guide to determine the correct vacuum pressure range for your specific model. If the vacuum pressure is below the recommended range, it could indicate a vacuum leak or other vacuum-related issue that needs to be addressed.
Throttle valve cable adjustment: In addition to vacuum control, the transmission shifting in your vehicle is also influenced by the throttle valve cable. Ensure that the throttle valve cable is properly adjusted and functioning correctly. A misadjusted or damaged throttle valve cable can cause shifting issues.
Feb 10, 2006 at 1:45 PM
