jeep cherokee 2.5 diesel glow plugs
JEEP CHEROKEE
XAVIERLENTH
hi there.. any idea how to remove and test glow plugs..
also a lound noise when starting is this the bendix in the starter? how would this be fixed..
also the buzzer which tells you the lights are on when the door opens dosnt work.
and seat belt warning.. any ideas..
thanks :P 8)
Mar 24, 2006 at 1:54 AM
PEPPERMRJ
  • 1,158 POSTS
To check the glow plugs, disconnect the power cable to the top of each one and check the resistance between the central terminal and the outer casing or cylinder head (ground) it should be below 1 ohm. Normally they will start on 3, but if you have 2 down they won't start from cold.
The buzzer could be anything from the light switch, ignition tumbler, the wiring, to a bad buzzer itself.
Mar 25, 2006 at 7:53 PM
