Jeep air conditioning leak
JEEP CHEROKEE
JOYLOU
I have a 1996 Jeep Grand Cherokee Laredo with 150000 miles and a 5.2 engine. When we run the air conditioning it leaks inside the jeep on the passenger side floor.
Aug 25, 2007 at 11:10 AM
GRICHARDS
  • 57 POSTS
It's likely that the AC "evaporator condensate Drain Tube" is clogged, disconnected, or cracked. Underneath the passenger side dash is an assembly called the "Heater/AC Housing" (Black Plastic). Connected to this assembly is a drain tube that goes from inside the passenger compartment, through the front firewall, then down so the condensation/water can drain onto the ground. EXACTLY where the tube is located on a J.G. Cherokee I'm not quite sure, it may route from the firewall then into the right front wheel well area (behind the splash guard). Most "Water in passenger floorboard" when AC running problems are this... Anyone out there with a JGC that knows the exact location? Hope this helps!
Aug 25, 2007 at 12:11 PM
