Headlight problem
JEEP CHEROKEE
MAMAS JEEP
2001 Jeep Grand Cherokee, 100,500 miles, 4.0L--Right low beam headlight does not work. High beam does. Both work on the left side. Checked fuses, changed the bulb, checked wiring not finding a problem. What am I missing??
May 5, 2007 at 8:59 PM
MERLIN2021
  • 17,250 POSTS
Did you get power when you gecked the wiring!
Should be 3 wires at the bulb with low beam on only 1 should be hot...If you get power at the light the ground is no good, check again!
May 6, 2007 at 6:28 AM
MAMAS JEEP
[quote:28cd8281c2="merlin2021"]Did you get power when you gecked the wiring!
Should be 3 wires at the bulb with low beam on only 1 should be hot...If you get power at the light the ground is no good, check again![/quote:28cd8281c2]
Only 2 wires to low beam both are not hot.
May 6, 2007 at 2:35 PM
MERLIN2021
  • 17,250 POSTS
Any water or moisture in the light? If it has only 1 bulb for high and low...look around for a haning wire...you need 3 wires! 1 for low 1 for high and a ground...
May 7, 2007 at 3:11 PM
