[quote:dcb11e0b19="kizdrawt"]2002 jeep grand cherokee 48000 miles. the electric fan will not run causing overheating. the fuse is good and used a test light to determine no power to the fan. does this have a relay? if so where is it ? auto parts store said it does not have a listing but it could still have one. please advise.[/quote:dcb11e0b19]
Im not near my diagrams for your car, but most of these systems are controlled by the PCM. It takes inputs from the engine coolant temperature sensor and the air conditioning system and decides when the fan is needed.
Most systems will run the fan, or one of two fans when you select the airconditioning on. The other relies on that temp sensor. I would probably replace the sensor. Find out from your parts store if they list more than one coolant temp sensor. Some cars do one for the indication inside and one for the PCM. Make sure you replace the correct one.
Aug 1, 2006 at 11:22 PM
